Cracked manifold on revo 3.3
#16
hello
I got spare never used , I want to trade for 2 donnel 97T glow plug if u want
new piece cost you 17.99, 2o donnel glow plugs cost you only 10.00....
and btw you can make it stronger by putting some overnite epoxy on those weak part
#17
if i get the spring loaded one. i wont have a problem again. correct?
#18
#19
#20
#22
anyone???
#23
you will also need this..
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUTF5
http://www.amainhobbies.com/product_...Spring-Gaskets
#24
#25
#26
ok i just received this one in the mail. http://www.amainhobbies.com/product_...Header-Tubular But seems like the clip that holds the spring doesnt fit the pull start is in the way am i doing something wrong. I noticed the manifold has to small holes am i not supposed to use the clip on my model?
#27
PULL START?
I have a question why does your traxxas motor have a pull start on it, and you should have mentioned that in you original post. Try to find a pull start freindly manifold for your motor.
#28
i didnt know it would matter. Can i use it without the spring clamp. and just use the holes on the manifold?
#29
You can use the manifold without the flange or modify the flange. The new Platinum header is really the old Big Block header with a smaller port and the flange added. The older BB header was used that way and this one can be as well.
#30
so trim the flange or just use the existing holes on the manifold for the spring?
