e revo help
Hi guys.
I tried to take my e revo out for a spin the other day but found that it seems to only be reving out and not really moving.... Anyone got any ideas as to what may be causing this to happen???? Any help will be greatly appreciated. Thanks in advance. John. |
Check your gear mesh, that sounds like the problem
what ^ said or maybe the slipper is too loose and not grabbing.
Start with the basics, like maybe the pinion?
i have checked the above. they are all good.
slipper clutch is as tight as it willl get... pinion is tight, and gear meshing was done properly. any other ideas guys???? cheers. john. |
open the black motor gear cover and see if the spur is rotating nicely when you give some trottle and not buckling or something.
If it passes, check if input shaft is rotating too, some times, even when spur is super tight, it still slips if thr is no clutch pads left. Next take off transmission skid plate (part no#5637) and check driveshaft and if the output shafts from the tranny is rotating. Maybe the driveshaft popped off or something. You could check it by removing the plate which is right under the tranny on skid plate held by single screw. I hope it helps you locate your problem. |
Basic #2
Make sure a wheel hex is not stripped or loose. |
yah the driveline popping off the tranny outputs happened to me. weird how both front and rear would break same time:flaming:
| All times are GMT -7. It is currently 06:31 AM. |
