-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   Differential help (https://www.rctech.net/forum/monster-trucks/3673-differential-help.html)
Evil_S10 03-12-2002 01:33 PM
Differential help
On my Traxxas Stampede, I just started to have trouble with the drivetrain. It seems as though the Differential is going bad, but I am not quite sure. I would much rather fix it than buy a new differential which will cost me around fifty to sixty dollars. Any help with this will give me some good info.
myclod 03-22-2002 11:29 AM
Fifty or sixty is replacing EVERYTHING in the trans including the case...First place to look for problems id the slipper clutch then with worn gears and bearings, remember you don't need to necessarily replace everything, Traxxas also makes a Hardened Idler Gear #1996X which is a common problem in those trucks.
Evil_S10 03-24-2002 06:24 PM
I have replaced all the gears except the differential. I changed them to the optional parts that Traxxas makes.
myclod 03-25-2002 04:32 AM
Egged out bushing or bearing? or a egged out hole or slot in the gear case?
Evil_S10 03-25-2002 01:12 PM
Bearings are perfectly fine and there is no problem with the gear casing. But to be sure I will buy a new one.
pusher 03-27-2002 08:36 AM
Make sure the white plastic outdrives arent stripped....
Evil_S10 03-27-2002 12:19 PM
They aren't, I replaced them when I first got the truck with Steel yokes.
Evil_S10 03-31-2002 03:46 PM
Any other comments or clues to my differential problem would be very helpful.
