Emaxx Gearing
Old 12-31-2009, 06:37 PM
rock3ralex's Avatar
Trader Rating: 28 (100%+)
Default Emaxx Gearing
What would you guys recommend in terms of tranny gearing in an emaxx running a Mamba Monster ESC, 2200kv Castle Motor or 1890kv Feigao Motor running on a 5000mah 5s lipo. How many teeth on the spur and pinion for good acceleration, top speed an non over heating the motor or ESC, basically not over or undergeared.
rock3ralex is offline
Old 12-31-2009, 08:57 PM
Trader Rating: 21 (100%+)
http://www.scriptasylum.com/rc_speed/index.html
Go to the speed calculator, then the top speed estimator. All the ratios yoiu need are in the drop down menus. You will be able to answer the ques by using this estimator.
Duster_360 is offline
Old 01-01-2010, 11:15 AM
rock3ralex's Avatar
i've used that before but that only tells me speed. It does nothing for me in terms of heating up the motor or esc.
Old 01-03-2010, 07:46 PM
phildoggg's Avatar
Trader Rating: 24 (100%+)
The gearing will be differant for the feigao or the castle neu. I'd aim for 45mph with either set-up. the cc/neu will run alot cooler though. I run 21/58 on my e-revo on 4s and it always runs cool. your gearing would be less for the same speed on 5s.
phil
phildoggg is offline
HTML code is On
