hpi baja 5t throttle problems
I am having serious problems with my throttle servo cutting out on my truck. Even if the truck is less than 5 feet away from me the throttle servo will stop working for some unknown reason. The truck is fully charged and my remote has new batteries. When it stops to work the steering will still work fine but when I hit the throttle trigger nothing happens. Turning off the remote the servo goes to its kill setting. Somebody mentioned that it may be my remote thats the problem but the truck is less than 1 month old. I already checked all the receiver clips for the servos as well. Thanks in advance.
Wrong forum bud, I suggest hpibajaforums.com
It seems the servo is not getting the signal, plug the steering servo in the throttle plug and the throttle servo in the steering plug. Turn on everything except the engine and try if the servo works as you walk away. (but now the controls are mixed)
This should show you where the problem is.
