ok guys revo conversion pinion help >
Old 12-31-2009, 03:04 PM
dmgriff266's Avatar
Trader Rating: 35 (100%+)
Default ok guys revo conversion pinion help
what is the tooth pitch on the spur gear on the revo 3.3 trans. need two know so i can order the pinions and use the two speed trans
thanks
mike
dmgriff266 is offline
Old 12-31-2009, 03:18 PM
Trader Rating: 21 (100%+)
The Revo uses what is called Mod 1 pitch spur and pinion gears. Its the same type used on 1/8th buggys.
http://www3.towerhobbies.com/cgi-bin...&I=LXHFR5&P=ML
Duster_360 is offline
Old 12-31-2009, 03:48 PM
dmgriff266's Avatar
thanks duster 360
HTML code is On
