xtm engine in tmaxx help
i have a xtm .21 conversion tmaxx.it missing one major part. help
i have a xtm engine. its the 24.7. it has the sg style shaft that has been shorten. i need the clutch nut shaft. does anyone know where i can get this part? i have a clutch nut shaft already but its for the regular shaft not the sg shaft. its different threads. the only place that i seen one was in the xtm .21 conversion kit. but i cant find those anymore. |
If I understand you right, you need the correct clutch nut for that shaft? I'm pretty sure this is the one you need..
http://www.myatomic.com/catalog/view...h_nutsg_shafts |
| All times are GMT -7. It is currently 02:34 PM. |
