LST XXL Breakin Problems >
Old 07-05-2009, 06:02 AM
Default LST XXL Breakin Problems
Hi, Iam new with monster trucks, just bought an LST XXL 2 days ago, I tried to breakin this morning and I found out that everytime i remove the glow igniter the engine shuts down, I reset the needles to the factory settings and its still the same.
I am at Malaysia and temperature here is around 29 to 32 deg C. Do I need to change my needles? I am using a 25% Nitro Fuel.
Also, I find it difficult to remove the receiver battery because the cable conenctor at the other end cant fit the space where they inserted the cable from below, very small opening an I am afraid that this design would damage the wire insulator when the engine is hot..
Help please.
Danabe
danabe is offline
Old 07-05-2009, 07:17 AM
For the engine problem - it sounds like you need a new glow plug.
howtowakeakar is offline
Old 07-05-2009, 07:37 AM
I just checked the Glow plug, its good, bright orange light.
Anything i need to do with the needles, its at factory default now.
danabe
danabe is offline
Old 07-05-2009, 08:04 AM
Glow plugs can go bad, even if they still glow. (The coil can get a glaze on it, preventing heat build up and dissipation.)
Replace it, and lean out the factory settings 1/2 turn on both needles.
Old 07-05-2009, 08:07 AM
DeadManInc's Avatar
Default xxl
try leaning out the low speed needle a little bit at a time until it will run without the glow ignitor
DeadManInc is offline
Old 07-05-2009, 10:06 AM
daniel15fl's Avatar
try letting the engine warm up, replace the glow plug and make sure there are no air leaks
daniel15fl is offline
Old 07-05-2009, 04:44 PM
Talking
Thanks guys, i'll try first run the engine until its warm, lean a bit the LSN, then if its still the same, replace the glow plug..
danabe is offline
Old 07-06-2009, 04:27 PM
daniel15fl's Avatar
i would replace the glow plug first
Old 07-07-2009, 07:43 AM
Wink
ok, thanks for the advise. I'll let you know, ill try this saturday..thanks..
danabe is offline
Old 07-07-2009, 09:16 AM
Trader Rating: 73 (100%+)
If it runs with the igniter on and dies when you remove it is because the engine is too rich. The glow plug remains lit between cycles because after combustion, the conditions are perfect for the heat to stay in the plug. Too much fuel and the plug will be blown out by the abundance of fuel. losi engines are known to be super rich when new.
I would go in a trun on the high speed needle, get the engine up to temp and then bring it to a safe tempreture by truning out the high speed needle if necessary. Dont play with the low end needle untill you get the high one set.
losifiend is offline
Old 07-07-2009, 07:47 PM
Thanks for the tips. I'll let you know later
danabe is offline
Old 03-29-2013, 02:08 PM
Markcuda's Avatar
Talking
So, what ever happened?
Markcuda is offline
HTML code is On
