t-maxx help
My t-maxx 2.5 with a 3.3 only runs with the front wheels only no rear wheel drive. Could this be a blown rear diff?
t maxx
it could be any of the driveshafts or the diff its ushally commonplace if a t maxx blows a diff out its ushally not the ring and pinion but ti could be we found that it stripps the spidergear pin inside the plastic spider gear case and you have to take it apart and clean it to find it REAL PAIN
Originally Posted by plumbnit
(Post 5476827)
It could just be blown bearings i would take the diff out and look at blown bearings or broken teeth, if its not making any sound when it runs (like a grinding noise) then your driveshafts could be stripped and its just spinning on the outdrive |
Have you checked the drive pins in the rear center drive axle? If you lose either drive pin (shaft has 1 in front at trans and 1 in rear at diff), the shaft will just turn and not drive anything.
These need to be checked/tightened every once in a while - all of them, there are a dozen - 2 each on all 6 drive shafts. |
| All times are GMT -7. It is currently 07:08 AM. |
