os .30 vg in revo >
os .30 vg in revo
os .30 vg in revo
Old 02-22-2009, 04:26 PM
Default os .30 vg in revo
does this sound right on the very first tank in order for it to even move i had to lean in almost a half turn from what the engine manual said which is 2 3/4 i am using 20% traxxas fuel and stock pipe im not a newbie and have broken in about six motors before but never had to make that much of adjustments to run first tank it just seems a bit much and on the first tank it got up to only 100 degrees like that im a little baffled so if anyone can help or if this sounds about right please let me know ps i dont want to switch fuel and or pipe
twayne81 is offline
Old 02-22-2009, 04:46 PM
forgot to mention only used 1/4 throttle first tank in about 35 degree weather
twayne81 is offline
Old 02-22-2009, 06:34 PM
Just let it idle through the first two tanks, then do 2 on 1/2 throttle, then 2 with short bursts of full throttle, no adjusting should be necessary. To be safe re-set all of the settings to what the manual says, just in case.
howtowakeakar is offline
Old 02-23-2009, 06:12 AM
i agree that much of adjustment was not needed but it was just pouring gas out of the exhaust while it was running after a 1 minute of idling it had a puddle the size of a nice size pancake and it was not from over priming
twayne81 is offline
Old 02-23-2009, 10:04 AM
madmaxx's Avatar
i have an OS .30 in my truggy and the thing is set PIG rich from the factory! i had to do quite a bit of leaning to it during break-in to get it to run properly and achive proper temp's....
madmaxx is offline
Old 02-23-2009, 11:45 AM
thanks madmaxx so you had a similar problem with your .30 vg after break in how did your engine run and about what temps are you running with the os .30 vg thanks in advance
twayne81 is offline
Old 02-24-2009, 12:47 PM
madmaxx's Avatar
i only have ~ 4 tank's on it so it's still not fully broken in, the thing has ALL kind's of torque but not much top end....
i was running between 220 - 230 IIRC
i remember coming across some info stating that the vg does not like temp's greater than 240 - 250....
as soon as we start to get some nicer weather i'll be outside burnin' nitro!
madmaxx is offline
Old 02-25-2009, 06:09 AM
i will be finishing break in today where im at it will be around 50 today i heard the same thing about the top end i am running stock gearing right now (38t,15t)but waiting to change to see how it goes but i would assume that i will go to 16t or 17t clutchbell to get a little more topend and still have that take off i will post back and let you know how the motor is doing
twayne81 is offline
Old 02-25-2009, 08:48 AM
madmaxx's Avatar
it may take you a few try's to get the gearing right, i think 15/38 is to high for that motor but am not shure what would be best 'cuz i don't run it in my REVO. if i had to guess i'd say prolly an 18t c/b and 36t or 34t spur. i run 17/36 with my picco and it has no prob's with those gear's....
madmaxx is offline
Old 02-28-2009, 06:18 AM
i finished break in and wow! this truck is so much more fun to drive endless power with that os ive heard that the topend wouldnt be that great but it hauls i have the dx3s and it clocked it doing 47 mph at 265 degrees i dont how accurate they are yet but i did calibrate the controller well anyways im very pleased with the end result and cant wait for the racing season to start
twayne81 is offline
Old 03-01-2009, 03:42 AM
Clippy's Avatar
Trader Rating: 45 (100%+)
Nice work. Im hoping to put a 30 VG in my Sav XL when I toast the std mill. Seems like they really do go heaps harder than the box variety engines.
Clippy is offline
HTML code is On
