AB Modded V spec in revo
I just wanted to give adam a big thank you for the rush job on the v spec. We ran at the local track this weekend and had to run in sportsman buggy with my revo. We TQ the field in first qualifing and in the second round ripped spur gear off of slipper clutch but time held up. Started main with the v spec in two laps stretched out 1/2 lap lead and disaster struck, tore off the spur gear again off the slipper clutch bolts and all. The revo was hooked up and i just wish i had a way to remove the slipper all together so we can put all the power to the ground! But the HP we had from the AB Modded v spec was awesome!!!!!! Thanks again adam. We could pass the buggies on the straights, so if you need some serious power visit ABMODS.COM
shannon williams
shannon williams
Hahaha! Good to hear you got ALL the power you need! Now it's just keeping that power from breaking things thats gotta be worked out!
Adam is "Da Man" when it comes to building mills for power and efficiency! AB Mods "always rockin' the house!"
