will a 2.5 crank fit a 3.3 >
Old 12-17-2008, 10:05 PM
savageboy69's Avatar
Trader Rating: 93 (100%+)
Default will a 2.5 crank fit a 3.3
I'm getting a 3.3 that has the ips crank for bumpstart and I want to know if a 2.5 crank will fit so I can use a pullstart
savageboy69 is offline
Old 12-18-2008, 07:03 AM
joe of loath's Avatar
pretty sure. they're the same engine except from the piston, sleeve, the hole for the sleeve in the case and the bottom of the head.
joe of loath is offline
Old 12-18-2008, 09:45 AM
helibrian's Avatar
Not to contradict, but I think the stroke on the 3.3 crank is almost 2mm longer. The PS cranks go for about 10 bucks on ebay. Of course you'll need more than just the crank to make it all work.
http://cgi.ebay.com/TRAXXAS-REVO-TMAXX-JATO-TRX-3-3-Engine-CRANKSHAFT-NEW_W0QQitemZ200288535012QQcmdZViewItemQQptZRadio_ Control_Parts_Accessories?hash=item200288535012&_trksid=p3286.c0.m14&_trkparms=72%3A1419|66%3A4|65%3A12|39%3A2|240%3A13 18
helibrian is offline
Old 12-18-2008, 10:07 AM
helibrian's Avatar
I dunno. My thinking could be twisted. It may be the bore that's 2mm larger. The bore is definitely larger. Take what I said earlier with a grain o salt. In the mean time I'll see if I can find an old 3.3 around here and take a measurement off it.
Old 12-18-2008, 01:44 PM
Trader Rating: 21 (100%+)
They are not the same part numbers 2.5 - p/n 5219, 3.3 - p/n 5288 which leads me to believe they are not the same. I'd expect the crank ports to be diff also - 3.3 needs to breathe a little more than the 2.5.
Duster_360 is offline
Old 12-22-2008, 10:27 AM
The crank will work, but you'll lose power because the 2.5 has a smaller port.
Pacific Rider is offline
HTML code is On
