Are 420 and 40 series the same?
I always tought the 420 was 4" and has 20mm hexes, so it should be no problem to use a 420 Losi tire on a Proline rim.
http://www.horizonhobby.com/Products...rodID=LOSB7010
losi 420 are not 4.2 inches.
420 means that it is a 4 inch wheel with a 20 mm hex.
They will only work on trucks that have losi 20 mm hex.
You can use any 40 series wheels with losi 420 tires. 40 series tires with will work with 420 wheels, except that you can only use them with 20 mm losi hex.
