MGT with Grave Digger body >
Old 03-24-2008, 10:51 PM
Cog
Registered User
Default MGT with Grave Digger body
Need some info. Doing up a fine paint on a Grave Digger body for my MGT but when I was measuring things up discovered shock towers need to be raised mucho.
Need extensions at least 4 inches longer than stock extensions. What have you guys used that have this body or where can I find something decent to use or am I just SOL and have to dig thru the " BOX " to find something to invent for extensions.
Cog is offline
Old 03-26-2008, 11:44 AM
Default In reply to your grave digger body
You might want to check www.rcboyz.com they had grave digger bodys and You might find post extentions also...type in ..body posts in serch box, you should find some thing there that might work for you..
slawhammer is offline
Old 03-28-2008, 08:56 AM
Parma has a variety of different length body posts for tall bodies, check them out. www.parmapse.com Part #10447
monsterbft is offline
Old 03-28-2008, 10:49 AM
R/C Lidz's Avatar
Trader Rating: 58 (100%+)
you need this:
R/C Lidz is offline
Old 04-01-2008, 11:40 AM
AcadDude's Avatar
Trader Rating: 19 (100%+)
I had to use post extensions for a Revo. Proline made the one I have. It's a ways up there in the rear.
AcadDude is offline
HTML code is On
