NEED HELP NEW E MAXX
Hey Guys,
I have a new e maxx tried to put in HV novak an it keeps shutting down!! Please help will take any Dandaman |
need more info. like battery charge, poled correctly, making sure the motor is hooked up properly, etc.
Are you running lipo batteries or nimh batteries, you may need a bec.
Is it going thermal? How much do you run your E before shutting down?
Are you useing stock gearing of the new E? Did you change your wheels and tires? As with what the guys posted. Post more info about the problem. |
I guess Dan has too much other crap to worry about. Thanks for not responding.:tire:
Does the esc have lipo cutoff? If you have the l ipo cutoff turnedon and are ru nning anyother kind of battery ie. nimh or nicd it will shut down prematurely all the time.. How long does it run befor eit shuts down? Is it thermalling?
| All times are GMT -7. It is currently 04:57 AM. |
