Tranny
Old 01-20-2008, 08:03 PM
pinky2252s's Avatar
Default Tranny
hello
the spur gear on my t-maxx wont grip the shaft that comes out of the tranny.
yes i have all the parts on
any one know why its not griping it?
pinky2252s is offline
Old 01-20-2008, 08:54 PM
pinky2252s's Avatar
seriously guys?
Old 01-20-2008, 10:02 PM
xsxracing's Avatar
Trader Rating: 33 (100%+)
I dont know much about the T-Maxx but maybe take apart and check it out and thene put all back together and see what happen's.
xsxracing is offline
Old 01-20-2008, 10:04 PM
pinky2252s's Avatar
i have 6 times
Old 01-20-2008, 10:05 PM
xsxracing's Avatar
Originally Posted by pinky2252s
i have 6 times
LOL!
Well thene idk pinky,If i was there probly be a different story.
Old 01-20-2008, 10:07 PM
pinky2252s's Avatar
anyone else?!
Old 01-21-2008, 08:44 AM
dieseldog20's Avatar
have you tightened up the the nut on the shaft. maybe the red pins are bad on the spur gear. try tightening it up see what happens.
dieseldog20 is offline
Old 01-21-2008, 08:57 AM
skuter-race-ta's Avatar
Trader Rating: 34 (100%+)
Post tranny
if you're using a rrp steel gear maybe you should check the edge shape of the shaft that hold the spur gear,check if it still has the egdes if theres a round shape,then its time for you to replace it.....
skuter-race-ta is offline
Old 01-21-2008, 02:56 PM
pinky2252s's Avatar
i cant tighten it because the spur gear doesnt grip the shaft.. or rather the little circle thing
Old 01-21-2008, 10:17 PM
fhm555's Avatar
The reason your spur gear is not gripping the shaft is because it's not supposed to, the front and rear slipper plates are fixed to the input shaft and the slipper gear spins between them. Hold the slipper plates, not the spur gear and you should be able to tighten it right up.
Once you get it tightened, if it's still slipping too much it's time to replace your slipper pucks, spur gear, or both. You can replace both for less than $10.00
fhm555 is offline
Old 01-22-2008, 12:43 PM
joe of loath's Avatar
check nothing's stripped, as there should be 2 flats on the shaft, and 2 flats on the slipper pads that mean theres no slop. you might have knackered the pads.
joe of loath is offline
HTML code is On
