-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   Engine Prob. (https://www.rctech.net/forum/monster-trucks/195813-engine-prob.html)
pinky2252s 12-15-2007 09:06 PM
Engine Prob.
when i start my car and drive up the street and come back and stop the idle slowly dies. lean or richen what needle?
joffthegoth 12-16-2007 01:59 PM
sort out your throttle linkage. if you take of the air filter without the engine running, turn on the electronics. full throttle then brake see how far the throttle closes. i used to have the same problem, what u might find is when you apply the brake the throttle closes a little more than when its idling even if it closes by about 1mm its still alot, trust me. correct throttle linkage is the key to performance. you'll know when you get it right but some cars take longer thatn others. experiment. hope i've been some help
Rookie 4.6 12-18-2007 01:01 PM
First make sure your idle gap is set to about 1mm, if it is try leaning off the bottom end needle as this will increase the idle. If you get it right but then find that it wont idle again next time you take it out you should tend to adjust the low end needle to get the idle right not the idle screw itself..
