-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   TMaxx Problem (https://www.rctech.net/forum/monster-trucks/193635-tmaxx-problem.html)
TMaxx-25 12-01-2007 05:09 PM
TMaxx Problem
Hey guys I have a Tmaxx with an OS 18. And for some reason I can no get it to start. The glow plug is good, it seems to be getting fuel. Just will not fire up. It has been sitting for awhile due to the fact that I have been out of town working for the last couple of months. Any suggestions????
cheesewhip 12-03-2007 06:08 AM
tmaxx won't start
return all needle settings to factory settings, make sure there is no fuel residue that may be blocking the fuel line or around the nipples of the fuel tank, make sure the glow plug glows when you attach it to a glow plug starter, check receiver, transmitter, ez start, and glow starter batteries..
nitro engines can be stubborn in colder temperatures, so i would keep the truck indoors until you take it out and fire it up. or you could take a hair dryer or a heat gun to it before you fire it up...
pinky2252s 12-03-2007 03:09 PM
yes the hair dryer will work or if you put after run oil in it before your start it will make it smoother to start
hyperguy 12-15-2007 07:48 PM
make sure that you are not using a cold or med plug if you are planning on running it in the cold. go get yourself a hotter plug
pinky2252s 12-15-2007 09:04 PM
do you have an ez start on it?
