Dynamite Tazer 19T
Dynamite Tazer 19T
Hi Guy
i have this speedo in almost 3 month it used to run pretty good in foward and reverse. but right now i having the problem the speedo only work on foward instead of reverse. so just wondering how to reset the speedo and where could i find the instruction manual. thanks for helping
halo bro whre did you get this esc? lol
i c
Instead of laughing at him (which doesn't help BTW), try and answer his question. There is BTW nothing wrong with the dynamite tazer line of ESC's, not everyone out there wants to race, some people just want to have cheap fun.
1: Turn on the vehicle and the transmitter.
2: Press the 'setup' button on the ESC and the LED will change.
3: Press the throttle full forward and press the setup button again WHILE holding full forward. The LED will change again.
4: Press the throttle full reverse and again while holding it there press the setup button. The LED will change again.
5: Put the throttle in neutral (centered) and press the setup button one final time. The esc should be setup now.
Do not take more then 2 seconds to complete each step or the ESC will back out of setup mode and you'll have to start over. Good luck.
- Matt
- Matt
