2007 ROAR Fuel Truck Nationals
1/10 fuel truck
Monster Truck
1/8 fuel truck
entry flyer:
http://www.roarracing.com/downloads/...Entry_Form.pdf
Monster Truck
1/8 fuel truck
entry flyer:
How rules apply ?, i mean at ROAR's site say that its 2 classes of MT's, but on the entry from just appear once (and not the rulebook .12 to .20 and .21 to .28 separation) ... can you clarify this ? (im from out of USA so i dont know how you manage MT class over there) ...
thanks,
thanks,
thanks,
thanks,
9.4.4.2 Monster Trucks are defined by fully compressing the vehicle’s suspension and measuring
a minimum of 1.5” from the flat surface to the underside of the engine. Two or three speed
gear reduction transmissions are required. Differentials residing inside the transmission
are permitted. All reverse gearing must be disabled for racing.
9.4.4.3 All Monster Trucks will race together unless sufficient entries warrant splitting the entrants
according to the specifications in the above table.
9.4.4.4 1/8 Trucks are all trucks which do not comply with rule 9.4.4.2 but satisfy the
specifications in the above table and the general Monster Truck rules.
9.4.4.5 Deleted in 2006
9.4.4.6 Drive configuration: Two or four wheel drive is allowed.
9.4.4.7 Tire rules
9.4.4.7.1 No tires created for other vehicle types even if they meet the specifications will be
allowed.
9.4.4.7.2 Cutting or modifying the tread is allowed. Modifying the tire carcass is prohibited (i.e.
no "CUT" tires - whether they started as a Monster Truck tire or not). Trimming the
mounting bead of a production Monster Truck tire in order to fit a legal rim is allowed.
9.4.4.7.3 All tire measurements reference the carcass dimensions and do not include the tread
depth or width. LP tires are referenced for the minimum 1/8 Truck size and measure
the absolute minimal diameter allowable in the 1/8 Truck class.
9.4.4.8 Bodies: Truck or SUV only (no buggy or car bodies allowed).
62
9.4.4.9 Bumpers are optional. If used, they may not extend further than 1" past the body, front or
rear, and may not exceed the width across the outer edges if the tires to each side.
9.4.4.10 Rule incorporated into 9.4.4.1 dimensional specifications in 2007.
9.4.4.11 Skid Plates must not extend further than 1" past the body, front or rear. Metal skid
plates and chassis components are only allowed if safely attached and pose no danger to
drivers, pit persons, or turn marshals.
9.4.4.12 3 channel radios are permitted. Control is limited to throttle, brake, forward speed
shifting, and steering.
