LOSI LST Transmission issues??????? >
Old 04-05-2007, 04:36 PM
Default LOSI LST Transmission issues???????
My Losi Lst is a pain in my butt I swear! Ok so now today it was driving but very sluggish. After it warmed up a nit it was driving well again but then it seems out of know where it did not want to go. It screamed motor would inguage fully and gears are spinning but the wheels will not move. If I pick the truck up it will begin to turn the wheels but as soon as I drop it back down on the ground it will not go anywhere. After I shut it dow and fired it back up again it did crawl around but then again it did not mover just ran. I am not very tech smart and would like any advise here besides buying this car or that car and getting rid of this one. I love this truck but it has been a pain since I got it.
Do you think the tranny needs to be replaced or possibly could it be an adjustment that needs to be made. I greatly appreciate any info
Vic
VICM is offline
Old 04-05-2007, 04:42 PM
jtracker's Avatar
Trader Rating: 28 (97%+)
Hey,
I had the same problem with mine. If I remember right I had to tighten up one of the dogbones going from the transmission to the front and rear diffs. Check all of them and see if any are loose. Make sure its on the flat when you tighten the set screw. Hopefully this should fix your problem
Let me know if this works.
jtracker is offline
Old 04-06-2007, 07:50 AM
2DMaxLST's Avatar
Clean and lube the OWB in the center of the largest spur gear. I use Serpent one way lube on mine.
2DMaxLST is offline
Old 04-11-2007, 01:18 PM
Default still problems
I did as you all informed but nothing worked. If I let it cool down and start it up the next day iw will slowly go and then stop and scream. Everything is cleaned and lubed, tightened as well. Shall I assume tranni is fried?
Vic
PS how difficult is it to swap out a tranny?
VICM is offline
Old 04-11-2007, 01:49 PM
Trader Rating: 48 (100%+)
are you sure nothing is loose...maybe even inside the tranny...one little scew can equal ....a
NitroLuver is offline
Old 04-11-2007, 01:59 PM
I have not taken the tranny apart, should I? It seems like everyone thinks the tranny isn't fried. I guess I will tear it apart to see. Is this what you suggest?.
Vic
VICM is offline
Old 04-12-2007, 07:26 PM
Ok well couldn't sleep, damn car was buzzing around in my head, so I got up and tore it apart. Everything in the tranny seems perfect, I went over evry screw etc made sure it was tight, then I adjusted the servo forthe reverse/forward control. I put it all back together and everything seems tight. Then the wife told me I could not continue as I had other things I had to acomplish so I never got to fire it up and test it. I will let you know tomorrow after work if this did the trick. Lets hope so!
VICM is offline
Old 04-12-2007, 09:25 PM
2DMaxLST's Avatar
It's the OWB in the center of the largest spur.
2DMaxLST is offline
Old 04-13-2007, 05:03 AM
beni's Avatar
I agree with 2D clean the one-way in the spur gear. You can check it by taking it off the tranny hold the cam it rides on and spin it. It should spin one-way and grab the other.
beni is offline
Old 04-13-2007, 05:55 AM
This has reverse, why would there be a one way bearing on the spur gears? I am a novice so sorry if that sounded really stupid! It makes logic since the reverse is one speed. Do you have pics that may help me? Also would a cleaning work or would I need to replace it?
thanks
vic
VICM is offline
Old 04-13-2007, 06:45 AM
2DMaxLST's Avatar
2DMaxLST is offline
Old 04-13-2007, 07:10 AM
beni's Avatar
thanks
vic
The one-way is there so that when it shifts into 2nd gear 1st gear can free wheel.
beni is offline
Old 04-13-2007, 02:41 PM
The OWB is opertating correctly. BUT now I see the unit as a whole is not working correctly. Could it possibly be the slipper clutch? When the gears are moving correctly this does not seem to move the tansmission like it does not engage. I think I am going to replace the whole unit, slipper clutch, owb everything, that is where the problem seems like it is.
To all
VICM is offline
Old 04-13-2007, 05:29 PM
beni's Avatar
Check the pin the holds the slipper cage to the shaft, and-or tighten the slipper nut.
beni is offline
Old 04-13-2007, 07:05 PM
the pin is there and I tightened the nut, but it snaps back I think the lock nut is shot
VICM is offline
