Stupid Question >
Stupid Question
Stupid Question
Old 03-16-2007, 04:25 PM
Default Stupid Question
Ok my Losi LST is acting up and I need some help. I Have it started up after swaping out the one way bearing and shaft. It is running but then it was cutting out after I gave it anything more than 1/8 throttle.
After adjusting the idle it is running, but it is idoling too heavy. The motor screams as soon as it is warmed and it just keeps going. The only way I get it to sit and idle is if I aply the break. I feel stupid it is probably a simple adjustment but I am tired and frustrated. Any help is much appreciated
Vic
VICM is offline
Old 03-16-2007, 06:40 PM
LOWGEARED's Avatar
Hows your throttle trim?
LOWGEARED is offline
Old 03-17-2007, 08:09 AM
Ok I am going to sound really stupid here. This is the first digital transmitter I have had, should it be low or high?
VICM is offline
Old 03-17-2007, 08:30 AM
bad_b4's Avatar
Trader Rating: 43 (98%+)
Smile
you could just lift the body up and drive a Team Associated Monster GT under it!
But no,for real,im gonna guess the temp is very cold outside? maybe you are running too cold of a glow plug or your glowplug is starting to go bad,or weak nitro fuel,make sure your nitro fuel is kept indoors.
bad_b4 is offline
Old 03-17-2007, 10:00 AM
hhmmm I will swap out the glow plug and see what happens I think I have a hot laying around.
Vic
PS yes it is cold today!
VICM is offline
Old 03-17-2007, 03:37 PM
LOWGEARED's Avatar
I definatly use hots in mine its freezing!!
Old 03-17-2007, 07:11 PM
Thanx. I will swap it out tomorrow. Hopefully it works. Nice and snowyperfect backyard bashing.
VICM is offline
Old 03-18-2007, 04:08 AM
Rookie 4.6's Avatar
Sounds to me like your trim is out or your throttle linkage needs to be adjusted? Take off the air cleaner and swith on your car and radio, next look down the carby, the slide should only be open about 1mm. If its open to far adjust the throttle linkage so it closes to idle.
Hope this helps...
Rookie 4.6 is offline
HTML code is On
