changing fuel %
when braking in my revo i thought i was using 20% blue thunder
but it turned out my son had droped a bottle of 30% and put a hole in it so he had pured it in a 20% empty bottle i have used about 1/2 of a gallon now before i found out can i switch back with out major problems |
i'll just try it
It's not ideal changing fuel - you can change downwards, but you can't go back up.
Long-term, it's best you stick to one fuel. Now the mistake is done, there's not alot you can do. However, if you intend to run 20% from now on, you should be fine. Or you could stick with 30% and ensure the head clearance is correct for that amount of nitro. Blue Thunder is a fuel often scorned by nitro 'experts'. Certainly, I've heard some horror stories. For racing, you might be better off finding some alternatives and give your engine a sporting chance of making it past the 1 gallon mark! ;) :D |
thanks for the info
what fuel would you use? and i do plan to use 20% from now on the lhs only sells blue thunder & traxxas and they seem to all run out of the traxxas . i would be willing to order a case at a time if you have a good vender that i could use. thanks again for your help |
O'Donnell, Tornado, Elite 'Pink Power', Supa Glo, are all fuels I've used on various engines and can personally recommend. Trinity fuels are very good from what I've been told.
I AM RUN TRINTY 30% MONSTOR HORSE POWER IN 3.3 REVO SAVAGE X MBX5 AND HAVE HAD NO PROBLEMS WITH THE FUEL AS SOON AS MY TRINTY IN GONE I AM GOING TO WERKS 30% HAVE SEEN IT RUN HAD TO LEAN OUT MOTOR TO RUN FUEL GOOD TEMP AN FUEL MILEAGE :nod:
