Wheelie King Official Thread
#31
Originally Posted by wagonman72
Mike you didn't call, I sent your chassis today along with a happy little suprise....You will like it. Oh and dont make PSO angry.....You wont like him when he's angry......LOL
#32
Mike
The stock towers will do fine for now.
Here's a setup.
Single shocks in front with spacers inside to limit droop. Use the same bumpstops from the outside of the shock. Pro4 pistons, you know the grey ones that come on the round tree. You use the #2 and #3 pistons on the truck. Whichever pistons are the most restrictive go on the front and the others go in the rears. Start with 30wt all around. 4 shocks in the rear. Black springs in front and one pair each green and blue in the rear. Also use the clear o-rings(same as the ones from the Pro4. Set rear and front a-arms to level. Use some fairly heavy diff oil in the rear diff with something lighter in the front. The hellfire body will work excellent with just a little trimming for the head. Trim the bottom of the front body mount to lower it in the shocktower. Use the twin disk brake setup but smash the pads/plates in a vice after you stick the pads on. After you have the pads smashed onto the plates edge glue them with CA. Experiment with rear camber and toe-in to get the truck steering like you want, I like to stand them almost straight up to help break the rear end loose in tight turns. This setup will really suprise truggy racers and I have seen it beat them a few of times.
Have fun Mike!!
Here's a setup.
Have fun Mike!!
#36
I wouldn't be too suprised to see it at around $180.00 in some shops. We'll see....
#37
Originally Posted by xxxkat
You need to post some photos up in my bad ride thread, Your "MONSTER" looks like it would be awesome, I can see the wacker motor their, I would be interested in "how" it got their. Very cool.
Uhh that's an FG 1/6th scale monster, the "weedeater" engine comes in that spot from the factory..... DOH!!!!!
Check out http://www.molzermoweryracing.com/ >>> I'm thinking of getting the stadium....
#38
#39
here is a video HPI put up.
Wheely King
looks like alot of fun and alot more durable then it presents itself to be. ill deff pick one up if they are under 200.
Wheely King
#40
Now considering that I have never seen a FG 1/6th scale monster how would I know "just" what I was looking at, and add to the fact that I have no interest in one, If I was going to buy something on that scale it would not be anything that molzer mowery racing sells.
#42
Anyone got comparison pics? How small is this MT.
