Official MGT/MTA4 thread!!!! >
Old 03-23-2007, 02:46 PM
  #31
Default MGT
Thanks, that is what I will do.
Originally Posted by rcracenut
I have not seen the integy shock towers.I have had the best success with putting limiters inside the shock.
Ginsu is offline
Old 03-24-2007, 03:42 AM
  #32
mach51's Avatar
Trader Rating: 31 (100%+)
truck doesnt need anything done to lower it for racing. just taking the spacers off the shocks will get bones level and thats what you want. lowering it less than that will eliminate the function of the suspension.
I like the Hardcore towers but went with Nova RC for the wing mounts.
mach51 is offline
Old 03-24-2007, 12:17 PM
  #33
Out of curiosity, what exactly is the problem with integy shocks?
Kensai is offline
Old 03-24-2007, 03:45 PM
  #34
rcracenut's Avatar
Trader Rating: 52 (96%+)
Yes you can get it close to where it works good without the limiters. But that would mean you have to use the stock springs which are too soft for the real jumps and full out racing. If you want to have the right springs you need the Associated red in front and blue in the rear. Now the springs are stiff enough you wont bottom out as easily on jumps and hard corners. But that means you need to put limiters in the bring it down to the race height.
As far as what is wrong with the Integy shocks? They dont put enough thread in the cap and body to hold together with the hard jumping action of racing. The caps eventually pop off.
rcracenut is offline
Old 03-24-2007, 10:44 PM
  #35
mach51's Avatar
Saxtons MGT setup:
http://rc10.com/racerhub/setup/racer...chal.2004s.pdf
I think Gosch ran red all the way around, cant remember.
mach51 is offline
Old 03-25-2007, 01:25 PM
  #36
Default Richard Saxton
I did not know the King ran the MGT! I am suprised for that very reason we don't read more about it in the magazines.
Ginsu is offline
Old 04-19-2007, 09:39 AM
  #37
Integy dose not use good quality Al. I have never had any luck with them
ruinx is offline
HTML code is On
