Motors, motors, motors - turns and RPMs >
Old 03-15-2024, 07:49 PM
Questions?? Motors, motors, motors - turns and RPMs
Old RC vet here but newb to all the new motors and terminology. Can someone explain how turns and RPMs have changed with brushed motors? I used to think that the lower the turns the faster and more RPM the motor would run at usually meaning higher speed. The larger the can - the higher the torque. I'm used to vintage trucks - so when I wanted something faster, I would switch from say a LeMans O5 to a Mega 360 (22T and 21K RPM) or a Trinity Speed Gem Monster Mash that was 16T 40K RPMs. Do current brushed motors still work the same way? What am I missing?
I put a Hobbywing QUICRUN Brushed 555 (really because I got a good deal on the combo with an ESC) which is a 13T and although Hobbywing states on their site this motor is good for monster trucks it only was making 14K RPM and was pretty slow in my old school Big Brute. I was thinking because it was a 13T - I would blow the gearset in a second but it wasn't fast at all. So, it can't be just the can size making that much of a difference. Trying to do some research and I came across 3 slot vs 5 slot - which may be another reason but to be honest - now I'm totally confused. Seems like the old rules aren't really valid anymore...LOL.
For example Hobbywing has 2 QUICRUN motors - a 540 30T can making 14K RPM and my 555 can 13T making 14K RPM - so what's the difference in these motors from an application standpoint? And how would these motors compare to the Holmes Hobbies 15T Retro Sport for instance? I need some of you young whips to tell me how it is now!
nick1ster is offline
Old 03-26-2024, 11:47 AM
I don't think there's really that much difference between brushed motors now and then overall, but one major difference is the majority of brushed motors are for crawlers now.
The more slots the more torque and smoothness at expense of speed. Most 550 basher motors these days are 3-slot (Reedy/Traxxas/etc) whereas crawlers are 5-slot.
both of those are crawler motors really, just for different size/weight crawlers. But they would also be useful in vintage vehicles or scalers. They run at the same speed because the 3-slot but higher turns and 5-slot with lower turns kinda cancels out, but the 555 will have more torque due to the larger can.
​​​​​​​And how would these motors compare to the Holmes Hobbies 15T Retro Sport for instance?
The Holmes 15T Retro sport is a traditional brushed mod racing motor, 3 slot, This Holmes page is incredibly useful: https://holmeshobbies.com/motor-recommendations and even charts motors they don't make.
As you can see they claim the 15T Retro Sport is 2900kV. On a 2S battery at full charge (8.4v), that's 8.4v * 2900kV. = 24360rpm.
jauntyfedora is offline
Old 03-26-2024, 12:37 PM
1995 Monster T's Avatar
I have found the lower the turn and more RPM the faster you will go. Single turns are great for monster trucks. I have tried many 540 brushed motors in monster trucks and found that they just don't compare to 550 size motors. Especially in Kyosho trucks. Use a 550 sized motor. The 540 motor just don't have enough torque for the gearing in kyosho monster trucks.
1995 Monster T is offline
Old 04-05-2024, 07:10 AM
So, is the real reason for the difference the # of winds? The old school Trinity Speed Gem Monster Mash was single wind 16T and 40K RPMs. Is this the major difference in why they are able to produce much more speed in a monster truck application? So the Holmes 15T Retro is - by definition, because of its lower turn count - it should be "faster" than the Speed Gem, but obviously doesn't reach that same RPM. Is the difference the winds and the Holmes is probably not a single wind? The single wind generally has more torque and punch down low to make it quicker off the throttle?
Old 04-05-2024, 11:13 AM
The monster mash motors are not Speedgem motors. They were designed for monster trucks with big tires to turn faster at the start. The Holmes retro was designed for what type? The only Speedgems motor for trucks was the Saphire 17 single 24K RPM. Big difference from the monster mash motors.@16 single 40K RPM The winds are how fast the power is released. Single all at once double start and top end ect. Quad had 4 power bands Brushed motors just don't last and require constant brush changes and cleaning. Brushless is way better. Lots of power and no cleaning. I have found that 550 size motors work better in monster trucks.
I found this handy kv convertor RPM to solve your problem. Kv to RPM Calculator - Calculator Academy Put in voltage and kv to get RPM. Your Holms 15t motor with 2900 kv doesn't even come close to 40 k RPM. To get to 40K rpm you need a 5700 kv motor.
Old 04-08-2024, 05:38 AM
nrtv20's Avatar
As stated above, it's about the number of slots on the armature. 3 slots was the type of motor used in racing and the 5 slot as stated is for power not RPM. Just think of it as 3/5 as fast. More pole activations to make a full revolution.
nrtv20 is offline
Old 04-08-2024, 07:55 AM
The 555 can has more torque for monster trucks with big tires.
The easy way to go faster now is to add more volts, the new high volt lipo batteries are fantastic as long as your esc can handle it
leadfootedfool is offline
Old 04-09-2024, 08:35 AM
Roelof's Avatar
A 555 motor is longer. with the same windings as a 540 is has more length wire and so a higher resistance making de current lower. Current is one of the factors determining the magnetism strength and with that the speed of rotation. The torque of the 555 comes from the larger surface of the rotor and magnets due the longer case.
And then the question what timing is set. Most silvercan 540 motors have a default timing, rebuildable 540 even more. The 555 is probably also a silvercan and maybe even with a zero degree timing because these motors are well used in electric tools.
Roelof is offline
HTML code is On
