Running EVX ESC on Single Battery Pack
Has anybody tried this? Would it affect significantly the speed?
hey, thats a good MOD. Its now like a super rooster. EVX are much cheaper and you can connect 2 motors automatically.
Performance
Will the performance be affected drastically?
Max volts 23 (16 cells)
Connector that powers servo and evx use 5-8 cells
Other side "dummy" connector use 0-12 cells
Sounds like a GREAT weight saving idea also
so then i can run any 7.2 motor i want??? and what about this adding a receiver pack will i need to do this
Any 7.2 motor will work, as long as it does not exceed the currnt rating of evx. It may be able to use about a 10 turn motor, not real sure. The numbers I gave you are for using the evx's built in bec not a seperate rx pack.
ok, can i use a rx pack if so would it hurt or help
