glow plug help
im running the mach .26 with MC59 plugs and each one lasts 1 run till it burns out but runs fine till it stalls or runs outta gas then the plugs dunfor
i dont think its the tuning cuz ive even treyed running it a little on the rich side......................................... is it a bad batch of plugs any input would be helpfull |
Possible air leak???blowing out lots of smoke but still getting hot=air leak :weird: And will usually total a plug every run.../or your piston and sleeve are ready for a pinch/replacement :(
Ya I whould think it's a air leak too!!
hmmm sounds very weird to me..........haveu tried any other plugs such as the duratrax gold racing plug or the OS a5 or the LRP R5??? i have used all these plugs except for the os a5 because i just bought 1 and they are all very good....i think ur engine has an air leak causing it to run lean and wen u run out of fuel it overleans the engine aLOT and then burns out ur plug....if u keep having this problem u might want to rip ur engine apart and replace all the gaskets.....
how much % nitro are u running? |
| All times are GMT -7. It is currently 02:40 PM. |
