Kraton Roller Build
Kraton Roller Build
First build I would appreciate your thoughts on compatibility or if I should swap something out for a better part. Items have just been ordered today so they can still be swapped out.
ARRMA 1/8 KRATON 4WD Extreme Bash Roller
1. Castle Creations Mamba Monster X 8S 1/6 ESC/Motor Combo w/1717 Sensored Motor
2. Robinson Racing Extra Hard Steel Mod1 Pinion Gear w/5mm Bore (18T) (19T) (20T)
3. Castle Creations B Link Bluetooth Adapter
4. Sanwa 101A31973A Mt-S 4-Channel Transmitter with Rx-482
5. AGFRC 45KG IP67-Waterproof Steering-Servo High-Torque-Programmable - Full Metal Gear Digital Brushless Servo for 1/8 1/10 RC Models, 180 Degrees A81BHMW&AGF-SPV2
6. SMC True Spec DV 22.2V 6500mAh 120Amps/75C with G10 plates XT90
7. Hota D6 Plus AC/DC with balance boards and charging adapters XT90
8. ProTek RC Clear Double Sided Servo Tape Roll
9. Fuse Battery XT-90 Connector Set
10. ProTek RC Blue Thread Lock (Medium)
11. Weller WE1010NA Digital Soldering Station
