Engine swap mounting problem
I have a 28 engine I want to put in MGT to replace the TTR 21, but the mounting holes are much wider apart on the new engine than the stock engine on the truck. How can I mount this engine on the stock engine mounts. The holes on the new engine are too wide apart to be able to open them up to fit it. Help Help!!!
buy a new engine mount man lmfaoOO
i had the same problem as i also have this truck. if you go on ebay there is a company called golden horizon that has a mount that will let you use both styles! like i said i have the same truck and had the same problem
i have the engine that is from the .21 mgt well the newer version wich is the pro 21 bxr and it bolts directly into the mount my savage has for hte k4.6 wich is a .28 soi dunno y they wouldnt fit....
on the old MGT the .21 the engin mounting holes were closer together! they were the same width across the engin but were closer from front to back
The Assoc. website shows the engine mount for the MGT as having slots all the way down on each side, so as to mount any engine. Will have to order one of these to put newer 28-32 engine. When bolting engine to this new mount, do the screws just self tap themselves as you are srewing them down. Anyone know? Thanks.
the screw goes down through the top and there is a lock nut you have to line up on the under side! its kind of a pain in the a$$ !!!!!
| All times are GMT -7. It is currently 09:09 AM. |
