Good choice for the Tekno MT 410 kit >
Like Tree6Likes
  • 1 Post By gavsta72
  • 1 Post By TwoBelugas
  • 2 Post By TIME MACHINE
  • 1 Post By TIME MACHINE
Old 01-13-2020, 02:29 PM
Stankfinger76's Avatar
Default Good choice for the Tekno MT 410 kit
Currently building the Tekno MT 410 kit. I知 curious if the Hobbywing EZrun Max8 2600kv motor/ESC combo is a good choice as a starter combo set for this kit? The only thing is it comes with TRX plugs. Is it easy to swap them out with Deans Plugs?Thank you for your assistance.
Stankfinger76 is offline
Old 01-13-2020, 09:50 PM
gavsta72's Avatar
Personally i would go with the Max8 4274 2200k combo, it comes with Deans or Traxxas plugs
The 2600kv is a 4268 can buggy motor, or 1/8 on road. It will get hot in the MT410. The 2200kv is a truggy/truck motor, it's got the extra torque for a heavier truggy or truck
You can always gear it up for more speed due to the extra torque. That's my $0.02 worth anyway
Stankfinger76 likes this.
gavsta72 is offline
Old 01-14-2020, 01:48 AM
The MT410 is very light for an 1/8 in practice mt, so you may be able to get away with 2600kv motor, but I too say go to 2200kv, more room for different gearing for different uses.
TwoBelugas is offline
Old 01-14-2020, 09:32 AM
R/C Tech Elite Member
TIME MACHINE's Avatar
Trader Rating: 65 (100%+)
2000-2200kv with a 16T or 17T pinion is pure magic.
I don稚 advocate using Deans or Traxxas connectors on 4S, but I知 sure you can get away with it.
gavsta72 and Stankfinger76 like this.
TIME MACHINE is offline
Old 01-14-2020, 10:52 AM
Steel_Rain's Avatar
Castle 1515 2200kv sensored. Backordered everywhere, but I think this is the best 1/8th scale system on the market for the $275 price point.
https://www.amainhobbies.com/castle-...145-03/p587669
https://www.towerhobbies.com/cgi-bin...?I=LXGMCY&P=ML
Obviously, the Tekin stuff is a little better, but more expensive ($315):
https://www.towerhobbies.com/cgi-bin...p?I=LXLYLP&P=7
I have two MT410's, one with each of the listed systems above, with the same tooth count pinion. I favor the Castle equipped rig because I feel the power curve is better/more linear for my driving style, especially since the newest ESC software was released last year.
Steel_Rain is online now
Old 01-14-2020, 01:33 PM
what connector would you recommend? I致e been out of the loop in R/C for 12 years. Deans was the good stuff back then
Old 01-14-2020, 04:59 PM
Deans are still good for low to moderate power applications, but they have some limits. I would run them on 2S or 3S without any worry, but stepping up to 4S, or other high amperage situations would be a no-no.
You can find lots of connectors that are better suited for the job. They are easier to solder, and easier to disconnect. Personally, I use XT90 connectors on everything I own, but EC5, bullets, or similar options would be great too.
https://blog.ampow.com/amp/rc-batter...eans_or_T_Plug
Old 01-14-2020, 07:41 PM
Default Kit questions.
I知 curious what else I値l need besides the obvious stuff when the kit arrives. Will I need the nuts to hold the wheels on? I know about the pinion gear, any other gears though? Little stuff like that. Thank you for your time.
Old 01-15-2020, 09:51 AM
You will only need the usual stuff.
- Esc
- motor
- wheels and tires
- servo
- body
- paint (for the body)
I went the extra mile and bought a chassis protector, T-bone bumpers, chassis brace, and an unbreakable body from Russia. Other than tools, you will have everything you need.
Old 01-15-2020, 09:58 AM
- Esc
- motor
- wheels and tires
- servo
- body
i appreciate the input. I think I知 all set to go now
HTML code is On
Copyright ゥ 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
