Like Tree3Likes
  • 1 Post By xirton
  • 1 Post By marco70
  • 1 Post By RCTecher12
TYRE CHANGE
Old 03-17-2019, 05:38 AM
THE BADGE's Avatar
Default TYRE CHANGE
Hello all,
I've bought some second/hand wheels with tyres, I want to spray the wheels so I want to remove the tyres, is there any particular way this should be done ?
e.g. do you cut the tyres off, bearing in mind I want to re-use them, & must they be glued back on, also should tyres be 'airtight' when squeezed ?
Any info greatly appreciated.
THE BADGE is offline
Old 03-17-2019, 07:42 AM
RCTecher12 is offline
Old 03-17-2019, 09:51 AM
xirton's Avatar
For best result, and easiest way, is to bake them in an oven. Watch this video and it shouldn't be too hard.
Mechanical removal is not recommended, nor is boiling.
<iframe width="560" height="315" src="https://www.youtube.com/embed/6nyunQ_Omh4" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
the rc guy likes this.
xirton is offline
Old 03-17-2019, 11:05 AM
timjs's Avatar
The oven method works everytime for me.
250 for 15 mins. If that doesnt do it I increase the temp by 20 degrees and do it again, repeat until theyre all done.
Do NOT attempt to pull the tires loose until everything cools, hot wheels are soft and deform if you try to remove the tires while theyre still hot.
timjs is offline
Old 03-17-2019, 11:31 AM
Old 03-17-2019, 12:14 PM
marco70's Avatar
the wheels in a steel pot with water, boil them until they come unglued, it takes about 10 to 20 minutes
Micah78 likes this.
marco70 is offline
Old 03-17-2019, 07:03 PM
Iíve boiled tires many times and it worked every time.
Micah78 is offline
Old 03-17-2019, 07:21 PM
Old 03-18-2019, 03:15 AM
timjs's Avatar
It stinks. Either way bake or boil, youve gotta ventilate the house.
In my experience, not every glue will let go at boiling temps. Hence why I now bake all my tires.
timjs is offline
Old 03-18-2019, 03:41 AM
the rc guy's Avatar
If I was taking off glued tires Id use a toaster oven on my back porch no smell in house .
the rc guy is offline
Old 03-18-2019, 04:13 PM
Old 03-18-2019, 08:34 PM
Originally Posted by SlowLST2 View Post
How was the smell? Thatís my question. The couple times I tried it, it smelled like I was boiling swamp water and it stunk my kitchen up for 2 days. The wife was less than thrilled needless to say.
I had a couple sets of foams get pretty wet though - they got dunked in the Mississippi cesspool for a few minutes. Despite my efforts to dry them, Iím sure a little Mississippi funk was left behind.
I use a turkey fryer and do it outside. Just fill the pot with water instead of oil. Fire up the burner and boil those tires. I realize not everyone has one of these. Itís better than putting them in my oven and stinking the house up.
Micah78 is offline
Old 03-19-2019, 07:54 AM
L.
Micah78 likes this.
HTML code is On
