New engine decision help
thinking of upgrading my 3.5 trophy to a better .21 motor like a novarassi or similar that makes about 2.7 or so hp . Will it be ok to do the swap and will I the stock differential and all gears be able to handle the swap? Thanks
Novarossi Bonito if you're going .21
Novarossi Elite 5
Novarossi P5XLT
Novarossi P5XLT
So if I put that motor in will I need to change any gearing? Like the differential gearing or can I leave it all stock and it’ll hold up ???
Reading is sometimes difficult....
3.5 trophy like the first post says . Will a new motor like a Novarossi work with the stock gears and differential? That’s my main question
But I would go for a new clutch, it will give you the ability to fine tune the clutch and that might be needed when you change the engine from stock.
That car comes with a pull start engine, you may need new engine mount and a starter box to use a race engine / non pull start engine
Novarossi also has pull start engines
It you have a good budget ..... you can buy os
If you have a good budget ..... you can buy os
