-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   New engine decision help (https://www.rctech.net/forum/monster-trucks/1033658-new-engine-decision-help.html)
Redheadrcguy 01-02-2019 06:39 PM
thinking of upgrading my 3.5 trophy to a better .21 motor like a novarassi or similar that makes about 2.7 or so hp . Will it be ok to do the swap and will I the stock differential and all gears be able to handle the swap? Thanks
Cardiak 01-03-2019 01:00 AM
Novarossi Bonito if you're going .21
fbrk8r 01-03-2019 04:59 AM
Agreed. Just bought another one from Navarossi Direct yesterday.
Pedro Jesus 01-03-2019 05:37 AM
Novarossi Elite 5
Novarossi P5XLT
Redheadrcguy 01-03-2019 09:25 AM
So if I put that motor in will I need to change any gearing? Like the differential gearing or can I leave it all stock and it’ll hold up ???
houston 01-03-2019 10:37 AM
what kind of car is it?
Roelof 01-03-2019 11:37 AM
Reading is sometimes difficult....
Redheadrcguy 01-03-2019 01:19 PM
3.5 trophy like the first post says . Will a new motor like a Novarossi work with the stock gears and differential? That’s my main question
NitroVein 01-03-2019 03:26 PM
Most likely not a problem as I believe HPI uses Hotbodies parts for things like diff case etc, though it seems like there is some options for upgrading the drive train...
But I would go for a new clutch, it will give you the ability to fine tune the clutch and that might be needed when you change the engine from stock.
houston 01-03-2019 05:15 PM
im use to race vehicles .... not sure what a 3.5 trophy is ....... guess i need to learn how to read ..... :rolleyes: :D
kgombe 01-03-2019 06:31 PM
That car comes with a pull start engine, you may need new engine mount and a starter box to use a race engine / non pull start engine
Roelof 01-03-2019 11:01 PM
Novarossi also has pull start engines
tom1974 01-04-2019 04:22 AM
It you have a good budget ..... you can buy os
If you have a good budget ..... you can buy os
kgombe 01-04-2019 07:01 AM
havn’t seen a 21 pull start engine from nova in a while... name a couple and help this guy out
