Hellfire owners!!
List the parts that you used to fix the slop in the front and rear wheels.
So far I have used wheelbase shims supplied with the truck to take the slop out of the back and forth movement on the outer hub carrier pin. What else ya got??? |
Anyone tried using different hub carriers or bearings???
What size shims did you use etc.. What other parts work for the hellfire? |
kyosho shim behind the wheel hex.
| All times are GMT -7. It is currently 04:46 PM. |
