Torque steer on monster trucks
I’ve been fighting this blasted tq steer on my lst and I need help.
It was an old school lst but now I’ve installed everything from a chop shop from a 3xle so I got all the beefy stuff better axles center diff minus chassis and steering basically.
This is a center diff conversion and diff fluids is 200/500/100.
It has sway bars raven springs 40w shock oil.
Servo is single 7955
Problem is that on power is always tq’s to the left sometimes violent like a drag car on stock suspension with too much power.
So for those of you guys with center diff style monster trucks what diff fluid are you running?
Am I too heavy on the fluids or got the weight placement wrong like heavy in rear vs light fluid weight.?
This is thing is a blast to drive with the exception of this issue.
Thanks in advance
Thanks in advance
If you can adjust the Camber; try it (add 0.5°).
Ok maybe I need to explain better.
It tracks straight drives normal and the truck is zeroed.
Give it gas at basically any speed the truck goes left never right.
I just got gone taking all the 1st gen suspension components and driveline off in favor of the 3xle truck suspension hoping the tq steer would go away but that didn’t help either.
What I have seen on videos is that when accelerating, one wheel is kicking to the left or right rappidly. For example on this video, seen between 3:19-3:22, some wheel wobble caused by torque steer and then corrected by TSM. https://www.youtube.com/watch?v=hN5HCeAmroE
As far as in my case I never really solved the issue, it is a bit better since I chaned to new wheels and driving on a dry road with no pebbles or water etc. And I have checked everything I think.
Me too some times has violent torque steer, I remember applying a bit too much throttle entering a ramp and the truck was thrown sideways, and I have never seen that before. When jumping it is important that those plastic ramps are straight, if one ramp is a bit off the truck will not jump straight. I also have a 4092 motor, they have alot of torque so I am not surprised if it has something to do with it. But the savage xl is balanced, all components in the middle and lipos on the side so the weight balance is good.
I wonder how the 3xle guys are doing since I know they are center diff
But I do know on 4-5s the truck isn’t doing it as much and I’m sure 2200kv in the 3xle isn’t as torky compared to a 4092 1480kv
I guess I’m gonna have to add some punch control in the truck lol
Hello ,
it is possible to know which type of motor support used and / or a picture of how differential is installed
thank you
thank you
thank you!
brilliant!
you dealing with torque drift not steer .. so are all tires same diameter?.. if its going left on straight away then left side tires are slightly larger or spinning faster than right.
