Smt10 lower control/suspension arms?
I just bought my kid a smt10 GD and 48 hrs later or about 5 packs, I need a new idler gear in the trans (slipper clutch came to tight from the factory?) and a new front lower control arm (hit a piece of drift wood).
I’m looking for lower control arms recommendations. I’m leaning towards vanquish because they look tough and would last. But the ssd arms look tough too plus they have ball ends which are easy to replace. I don’t think the vanquish would break but I’m not into buying things twice. So what do you guys think?
And are the front and back lower control arms interchangeable? They look the same but thought I’d ask.
Nothing wrong with VP in most cases but definitely not their trailing arms. The rod ends wear way to fast.
I would choose the SSD over the VP simply because of the cost, the rod ends are Frenched in making them a beefier solution and I have read they are a little less wearing on the aluminum itself.
For me, I would go SS JAC Trailing arms for a bullet proof scenario and just a few $$ more. Plus you get color choices.
https://supershafty.com/collections/...i-score-bomber
Do you have any recommendations for the transmission gears? I was thinking about replacing all three gears with Hot Racing ones. They have a light weight set but didn’t figure it would make much of a difference so was leaning towards the regular weight ones. As for the transmission case, is there any real benefit to having aluminum ones.
If you have the $$ and the trans is opened up I would do all 3 gears and good bearings like Fast Eddy or Avid. After that then a SS motor plate and a Robinson slipper if the stocker can't hold whatever power you have. The lightened vs regular is not really and issue IMO unless you are building a lightweight comp rig. Whatever is cheaper and available.
The Alum case is nice but again depends on your funds and power. Unless you are big brushless power it is more bling than anything.
My last SS Clone I pieced together
Do you know if anyone makes a auto differential locker or a selectable locker that would work on the smt10. I looked around and couldn’t find anything.
I like the ssd trailing arms as well. The rod ends aren't the strongest but easily changed.
I run the hot racing trans in mine but about any metal trans years work very well.
