Proline Pro MT 4x4 >
Proline Pro MT 4x4
Like Tree99Likes
Proline Pro MT 4x4
Old 08-05-2018, 08:10 PM
  #526
hey guys, i love my mt4x4 but i feel like i don't have the right combo for it... with that said, i have the hobbywing EZRUN MAX 10SCT with the 3660sl 4000Kv. it runs 50 MPH on flat ground, and rips on the jumps off road, with a 3s (15 t pinion) but she runs really hot, enough to go into thermo only after a short time. basicly i want a combo that i can run fast on 3s (monster truck club rules) and not heat up quickly. thanks!
should i just put my current setup in my Tekno 410?
traxxas fan likes this.
3 x a charm is offline
Old 08-06-2018, 10:27 AM
  #527
Trader Rating: 18 (100%+)
I suggest a 1/8 scale esc if you prefer hobbywing a max8 and a 1512 2600 or 2650 kv motor and gear up a bit 18tooth pinion.
traxxas fan is offline
Old 08-28-2018, 01:08 AM
  #528
Backyard RC's Avatar
I ran my ProMT 4x4 on 4s today and the rear bearing that holds the center drive shaft in the rear diff came loose. This happened once before and I put the bearing back in with no damage to the gears.
The rear shocks don't seem to be able to handle the extra weight of the 4s battery and system. I'll have to up the weight on the shock oil.
Backyard RC is offline
Old 08-29-2018, 05:47 PM
  #529
RCWERKZ's Avatar
https://www.youtube.com/watch?v=_SbIiP2MWGo
nice! You can try a 4s pack that is the same dimension as a 2s lipo from SMC and/or Protek.
RCWERKZ is offline
Old 08-31-2018, 04:32 PM
  #530
Hey, RCWERKZ is in the house. Good to hear from you! Thanks for the tip. Is it 3000mah or something like that?
Old 08-31-2018, 09:01 PM
  #531
AJ DRAGON's Avatar
Hi
Does anyone know of any other springs that will fit on this truck?
AJ DRAGON is offline
Old 09-03-2018, 06:14 PM
  #532
Proline has a spring set for the front or the rear. https://www.prolineracing.com/perfor...ment-front.asp
Old 09-04-2018, 02:22 PM
  #533
AJ DRAGON's Avatar
Hi
I don't think those Powerstroke springs will work, the Pro 4x4 uses 16mm big bores.
Old 09-04-2018, 03:00 PM
  #534
werner sline's Avatar
who got the most backflips out of this little truck, so far ? i think this little short guy can be the king of backflips !
werner sline is offline
Old 09-04-2018, 06:57 PM
  #535
Default Pl mt 4x4 steering
Got about 12 good bashes in with this truck and everything has been good except for the turning radios. I have adjusted the servo numerous times, made sure nothing was binding, tightend up the saver nut and still can't get full left and right steering. I have even tried 2 different servos. Going crazy never happened to me before with a truck. But wow can this truck take a beating!!! 6s all day with it
boucher77 is offline
Old 09-04-2018, 09:53 PM
  #536
Oh wow, I never had Powerstrokes before so I thought that's what the ProMT had. Tekno SCT and MT410 have 16mm shocks.
If the pillowball screws are too tight it can bind up at full tilt. That may not be your issue but it's worth looking at.
Old 09-09-2018, 12:02 AM
  #537
AJ DRAGON's Avatar
Hi
What do you guys do to keep the servo wire from rubbing against the center diff cup?
Old 09-09-2018, 04:26 PM
  #538
I tried searching and didn't find anything so, sorry if this has been covered. I've had the MT 4x4 for a little while and haven't bashed hard with it, and today it started clicking under hard acceleration...very similar to a diff with the gears skipping/stripping. I took a quick look at the center and rear diffs, all looked good. Put it back together and it was fine for a while but started again. So I pulled the center diff again and cleaned off the diff fluid to get a look at all the gear teeth clearly. One of the side gears had shed a tooth and it was occasionally getted chewed on by the other gears since the tooth was floating around in there.
So, I looked up the part number in the Pro MT 4x4 manual for the replacement gears, and here's where my questions come in. According to the listing for p/n 6092-06, these gears are for the "Performance Transmission" they sell for Slash, Stampede, etc. So one question is, has anybody had problems with the diff gears? The other question is, am I the only one that finds it questionable that the gears used for the diffs in the Pro MT 4x4 are the same ones they use in the "Performance Transmission" intended for much lighter and lower powered trucks/buggies? Do I have the right part number?
Overtorqued is offline
Old 09-09-2018, 10:33 PM
  #539
AJ DRAGON's Avatar
Hi
How much lube was in the center diff when you opened it, mine was all but empty and I haven't even driven it yet. Or maybe you just had a bad gear. Yes those seem to be the same gears,
Old 09-10-2018, 05:55 AM
  #540
Mine had some fluid in it, but not much. I forgot to add above that I did clean out the original fluid and put in 500k fluid (not filled all the way though).
