New: Losi Mini 8ight Desert Buggy >
Like Tree28Likes
Old 07-13-2017, 05:03 AM
  #31
Did you already put everything on a new chassis? Looks blue in the picture.
jmickle11 is offline
Old 07-13-2017, 06:55 AM
  #32
yes i have lots.
check out my Youtube channel and you can see all my 1/5 scale trucks in video.
RCMK 1200SE, MTXL 12S brushless ( doing a backflip ) Xmaxx, DBXL-E.
here is one :
https://youtu.be/D6Q7XC1tZd0
Trout
trout74 is offline
Old 07-13-2017, 06:56 AM
  #33
MTXL backflip.
https://youtu.be/zsjXSL-sdkM
Trout
trout74 is offline
Old 07-13-2017, 06:58 AM
  #34
That little blue one is a Micro, losi 1/24 scale micro, lol
Trout
trout74 is offline
Old 07-13-2017, 07:04 AM
  #35
Trout
That's funny! Wished I never would have sold my Micro a few years back!
Old 07-13-2017, 08:52 AM
  #36
RGunn's Avatar
Wonder if the slightly heavy duty 48-pitch, 60T spur of the DB will fit the standard Mini 8ight Buggy? I know the standard .05-pitch on the Mini 8ight is 58T but the overall gear ratio can be adjusted with pinion T-count changes.
Wonder if the 48-pitch will show a significant durability increase over the .05-pitch (roughly 51-pitch equivalent)???
Wonder if going forward Losi will change all the Mini 8ight series to 48-pitch???
RGunn is offline
Old 07-13-2017, 02:37 PM
  #37
Wingnut44's Avatar
Trader Rating: 20 (100%+)
So we know this thing has the chassis from the truggy, but what about the rest of the parts?
I ask because of upgrades (CVDs, Turnbuckles, etc) and replacements. I assume they use the shorter ones off the buggy, unless they are new parts. I was also wondering if the tbone bumpers from the buggy or truggy would fit on here
I already broke the front gearbox so while I'm in there I might as well upgrade :P
Wingnut44 is offline
Old 07-13-2017, 05:19 PM
  #38
RGunn's Avatar
The chassis on the 8ight, DB, & Truggy are all different from each other. Take a close look at the pics on the Losi site.
EDIT: I stand corrected. The actual 'chassis' is the same part for the DB & Truggy. It's most of the plastic that bolts to the chassis that is different between the two. Sorry for the misinformation.
RGunn is offline
Old 07-13-2017, 06:20 PM
  #39
It uses a mini 8ight T chassis with buggy arms, links, and driveshafts. So it's long and narrow.
noel02 is offline
Old 07-13-2017, 06:25 PM
  #40
I had mini 8ight T for awhile and went through diffs like crazy. These diffs are much stronger, and the spur is stronger. The front steering bellcrank is different too and aluminum. This truck is much better out of the box than my mini 8ight T. Still room for improvement of course.
Trout
trout74 is offline
Old 07-14-2017, 12:35 PM
  #41
Wingnut44's Avatar
Exactly what I thought, thanks.
Old 07-17-2017, 01:08 PM
  #42
Trout
Any chance we can use the diffs from this in the Truggy?
Kalvin
zerokalvin is offline
Old 07-21-2017, 06:49 AM
  #43
Hey guys... I've only been into rc trucks for about 9 months, so forgive me if this post/question is out of place. I hope it's okay to post this here. I've been driving a Losi 22sct 3.0 and want to play with some of the other mini's I've seen locally. Mostly HobbyKing and Traxxas, with some occasional older Associated 1/18 scale. I've been pretty happy with my Losi, and I was looking at the buggy, but then I saw this. I do like the look of this a little more than the buggy. Obviously, they are two different machines, but if you were to choose between this and a buggy, which would you choose?
I run mainly on an indoor low grip track and may start running a little on a local outdoor turf track on occasion. Mainly just looking for something fun, nothing overly competitive, but I don't want the slowest car out there either.
LittleTreeGuy is offline
Old 07-21-2017, 07:00 AM
  #44
kevinatfms's Avatar
Tacon Soar Brushless Edition bar none. Seriously competitive, great price and the electronics are smooth at any throttle input. Tires are great, chassis is aluminum, shock towers are aluminum, has a slipper clutch with aluminum motor mount. Alot of features for less than the Losi.
LC Racing is the company that builds the Tacon Soar while Nitro RCX rebrands them. Getting parts has been quite easy as you can get them on Nitro RCX, Amazon and Ebay. My only gripe is that i lost a pin off the driveshaft on my SCT version of the Tacon lineup. New driveshaft was $7 shipped and havent had any problems since.
kevinatfms is offline
Old 07-22-2017, 08:48 AM
  #45
I lost a bunch of those and shredded 5 diff ring gears and 2 diff pinions on my truggy. I don't recommend any LC Racing mini anymore because of my bad luck with them. I probably had a lemon though, seeing as so many people have great luck with them.
It'd go with the Desert buggy over the buggy. It has a 380 motor, stronger diffs, and an updated steering rack.
noel02 is offline
