New: Losi Mini 8ight Desert Buggy >
Like Tree28Likes
Old 02-06-2019, 09:10 AM
  #346
Targeting, I read a lot about the Losi mini vs the LC Racing and there are fans in both sides... but not sure I trust most the opinions. I do trust your opinion though and would love to hear your thoughts on the differences between the Losi Mini 8 DB and the LC Racing 1/14 DB.
Thanks for all the awesome vids and builds!
smirkracing is offline
Old 02-11-2019, 12:16 AM
  #347
targetingxmod's Avatar
LC Racing is a pure racing machine ready to RACE.... (with still alot of options from LCRacing itself rather then aftermarket parts)
Losi Mini8ight-DB is a pure RTR (Ready to REBUILD) machine...(with a lot of aftermarket options that must BE installed or else it decays at every pack runs)
Things that happen to me and are notorious for other people on the Losi Mini8ight-DB:
-The runaways from the rx/tx...are caused by the antenna that sits horizontally along the batery and motor (worst possible scenario for a rx antenna!!!), and is not VERTICAL. Once you got vertical outiside the body problem goes aways permanentley. They should solved this at the factory...but...(If you want to keep stock rx/tx) this is a fix!
-The stock motor will not handle 3s at all. It will last only a pack or less...i did this runing stock gearing and at the end of the first pack, motor was smoked. I only run 3s on this thing (take note i use a big lipo)
-Dogbones are made of brass/pot metal. Better if was plastic instead.... it's a downgrade from the Losi Mini 8ight buggys!! I use to run 4s and 5s on speed runs for YEARS and still got the same dogbones! This on a 2 to 3 packs they bent! Need to find harder ones of go CVD's...
-ESC needs a fan...which is easy job to do...but should come stock!
As for the LCRacing DB...since it's a racing machine i will stick to 2s and put the biggest lipo it can fit, and call it DONE! Having one issue... stripped spur's...need to figure that out! Don't know if motor slides from motor mount, even loctited, or to BIG lipo...or there is something more (second hand, things!!)...that i still haven't figure it out...i am on my 3 spur in a half a dozen of packs...maybe going steel and loctite everything and should do, hopefully!!
Just my 2 cents about this matter...
I like the 2 rc's..if you can, or pretend to stay in RC 1/14... buy them. One each year! That's what i did.
The Mini8ight DB was bought new, and the LCRaing DB bought second hand...
targetingxmod is offline
Old 02-11-2019, 02:45 PM
  #348
Backyard RC's Avatar
I had a lot of problems with stripped gears until I used the Hotracing steel spurs and pinions. No more problems after that.
Backyard RC is offline
Old 02-17-2019, 08:03 PM
  #349
Vcoupe's Avatar
Hey mini fans I have my M8T fully kitted exotek, Carbon, aluminum you name it on the bay. Just search mini 8ight T
Vcoupe is offline
Old 02-18-2019, 04:15 PM
  #350
Here's what happens when you give the controls to the kids.
Old 02-21-2019, 12:32 AM
  #351
Vcoupe's Avatar
https://www.youtube.com/watch?v=ermXdWiWqbU
hey I like your Aussies bro, I have a husky. Blue eye mix?
Vcoupe is offline
Old 02-22-2019, 07:04 AM
  #352
Hey man,
I'm not sure what you're referring to. There's no dogs in that video. I'm a big fan of the huskies though. Beautiful dogs.
Old 02-27-2019, 05:52 AM
  #353
Hi amigo nice to see you all,
Just writing from Lyon, France, do you where I can find some Custom Bodies for the Losi Mini Eight not Truggy ?
daniboun is offline
Old 02-27-2019, 05:57 AM
  #354
Hello amigos,
Any idea where to buy in Europe a Custom Body for the Losi Mini eight, not truggy ?
daniboun is offline
Old 03-01-2019, 05:39 PM
  #355
Hello,
Here are a couple places you can get bodies for the mini 8ight.
https://phatbodies.bigcartel.com/
LC RACING Store, LC RACING|Brushless ESC: Car|Buggy|For LC Racing|Free Shipping|Mini & Micro|Rally C-
Old 03-05-2019, 05:26 PM
  #356
flat6's Avatar
Trader Rating: 346 (100%+)
Does anyone happen to know what the stock shock length (eye to eye) is for the mini 8 dB? (In millimeters).
Thank you.
flat6 is offline
Old 06-27-2019, 09:37 PM
  #357
Thank you.
~62mm front shocks eye to eye, 71mm rear.
Cirasa is offline
