Micro 1/24 SCT Tighter Throttle >
Old 10-11-2016, 06:45 PM
Questions?? Micro 1/24 SCT Tighter Throttle
Hi,
A while ago I added tape on the stock tires to do drifts on carpet in my apartment and probably crashed a bit too much in stuff and now I'm running into an issue with it.
After crashing one too many time into a table leg, it started doing a different sound than before as well I noticed the throttle to be tighter or not as smooth as before. Also sometimes when I want to go forward on really low speed it stops midway and does that sound when you try to go backward and forward too fast (even though I'm only making it go forward).
Any have any idea why it is doing that?
pingpaul is offline
Old 10-12-2016, 11:50 AM
JatoTheRipper's Avatar
Is it a brushed or brushless motor? If it's brushless check to see all 3 wires are attached to the motor and ESC. If I remember correctly the wires in the Losi brushless motors tend to pull out.
JatoTheRipper is offline
Old 10-12-2016, 05:09 PM
Brushless, I'll check that out, thanks
pingpaul is offline
Old 10-14-2016, 05:29 PM
Thefoodman52's Avatar
Take it apart man. Might have bent a dog bone, might be differentials. Could be spur gear issues, could be just stuff wrapped around the shafts and input or output cups.
Looking at it and asking why it's making sounds won't fix it. Take a #00 Phillips and some needle nose pliers, and get to it. Have pictures of new parts to compare yours to on your phone as you go, that way you can see if anything looks abnormally worn down.
Thefoodman52 is offline
Old 11-12-2016, 10:17 AM
That's a good idea, I filmed it and wonder if it's normal behavior or not, do you think I should take it more apart?
+ YouTube Video
pingpaul is offline
Old 11-17-2016, 02:38 PM
It looks like your motor can separated from the motor face plate. I had that happen last weekend. pull out the motor, and you can glue the can back on the face plate. Assuming you haven't hurt your esc or windings, you'll be fine. In my case, I burnt out a FET on the ESC, so I need to replace my mainboard.
Nerobro is offline
Old 12-04-2016, 05:02 PM
That was the issue lol I must of crashed too many times in walls that the motor went off. I just pop it back in there and it works fine. By curiosity what kind of glue did you use? (in case if this happens again)
pingpaul is offline
Old 01-06-2017, 08:51 AM
I used thin CA on mine.
Nerobro is offline
