Traxxas Latrax battery performance help?
Local track runs these stock Latrax/Traxxas SST trucks as a spec class. They use the small 1200mah 6cell 2/3 size nimh flat packs. Back in the day we could get some increased voltage out of these. I'm using a CE Turbo 35 to cycle them. Does anyone know of any ways to increase voltage and decrease IR on these little battery packs?? Thanks
Help
Ttt
Trader Rating: 7 (89%+)
not sure of how many capacity mah you batt have....probably 1200 to 1600?
you could always try to charge them at 2.5 - 3.0 amps. it will give you more punch but your battery will not last long. and if you charge them at high amps, keep your face away LOL
you could always ask Team Scream if they still have good battery. back in the day, i was sponsored by them and let me tell you that those batt had very good number.
