Like Tree59Likes
LOSI MINI 8IGHT-T!!
Old 03-25-2020, 06:54 PM
  #2986
Does anybody here own an lc12b1 or truggy as well as a mini 8ight-t?
cwinn93 is offline
Old 03-27-2020, 06:33 PM
  #2987
Does anybody here own a mini 8t as well as an lc12b1?
cwinn93 is offline
Old 03-29-2020, 08:43 PM
  #2988
Stevenator128's Avatar
Originally Posted by Backyard RC View Post
Can you put a washer on the nut side to give you more threads and a stable pressure point for the wheel?
That's kind of what I did with the plastic spacers I cut up. They're like a thick washer or bushing I guess, depending on terminology.
I've ordered some 12mm wide 12mm hexes to see how that works for me; I'm just hoping the axle size works out.
​​​​​​​Your same question from two days before is still there, I'm sure if anybody does they will see it. What are you trying to figure out?
Stevenator128 is offline
Old 03-31-2020, 09:05 AM
  #2989
Tech Legend
Cain's Avatar
Trader Rating: 268 (100%+)
buddy of mine has the mini 8ight-T and I own the LC12B1. We race a variety of mini sized vehicles at our track.
What would you like to know?
Cain is offline
Old 04-01-2020, 11:29 AM
  #2990
Sorry about the double post i didnt see that it had posted after rechecking the thread for answers so i reposted. Im curious if the bolt pattern of the diff cases where they bolt to the chassis are the same?
cwinn93 is offline
Old 04-01-2020, 12:23 PM
  #2991
Tech Legend
Cain's Avatar
hmm, wouldn't be able to fine that out till aftert some of this corona stuff passes. I'd say no offrhand though from what I recall but could be wrong.
Cain is offline
Old 04-14-2020, 07:28 PM
  #2992
Picked up my mini 8 t last week and after a back yard jump session started hearing the diffs clicking. After taking them apart I found I broke a couple teeth on the front and rear diffs. Ordered 2 V2 diffs and wondering what else I’ll need to get? I’ve seen some talk about a shim kit and what about grease or oil for the new diffs?
Blubyu1 is offline
Old 04-15-2020, 08:10 AM
  #2993
Backyard RC's Avatar
Unfortunately the diffs are a weak point on the Losi mini 8ight vehicles. Even my small buggy would break teeth. I don't remember the size but a shim or two should help and if the diffs aren't sealed then I just put some grease in them.
Backyard RC is offline
Old 04-15-2020, 08:54 AM
  #2994
jg6743's Avatar
here's a link for the axle shims. Install between bearing and diff... I do mine on the tight side and they are perfect after breaking them in.
https://www.amainhobbies.com/crc-8mm...cln4738/p53206
Backyard RC likes this.
jg6743 is offline
Old 04-18-2020, 07:25 AM
  #2995
Hi, could anyone point me in the right direction on how to dismantle the rear diff please? Looks like one of the diff outdrive set is loose and I cant see what is causing the problem. Thank you.
ROTH1 is offline
Old 05-30-2020, 07:21 PM
  #2996
notch johnson's Avatar
Default Wheel bearing size
Hi guys what is the outter hub wheel bearing size?
notch johnson is offline
Old 05-30-2020, 07:30 PM
  #2997
blankenj99 is offline
Old 08-31-2020, 06:45 PM
  #2998
Default Canít find tires
I cannot for the life of me find off-road tires for this anywhere the mini pins are sold out, what others options would you guys reccomend? All the tires I have on hand are not the proper offset and the wheel nut bottoms out before tightening the wheel to the hub
Strongbox18 is offline
Old 09-01-2020, 04:55 PM
  #2999
slick2500's Avatar
I'm a little late but no the bolt patterns are different.
Do you mean wheels? Have you tried the ones from the Lc Racing truggy? https://casterracingmi.com/index.php...=ASC&limit=100
slick2500 is offline
Old 11-20-2020, 09:51 PM
  #3000
Sup guys! Discovered this forum while looking for upgrades lol. I think my wallet won't like me . My motor shaft decided to break in tall grass... so yeah, you'll see my little demon soon enough fully rebuilt here! In the meantime, where do you guys buy the diff shims? Kinda want to add those before having to change my diffs.
RIPmyPC is offline
