Mini 8ight Speed Calc Guaging interest >
Old 08-22-2013, 08:14 PM
Default Mini 8ight Speed Calc Guaging interest
Since Ive busted my bulk on the M8 and recently openned it up, I counted the teeth on the ring and pinion to make the calculations needed to calculate the theoretical top speed. Obviously RC weight and increassed load from increassed gearring etc will keep the motor from hitting max rpm and in turn max speed, this can be used to get an idea of what changes to the gearing will do and it can also be used to calculate your gearing with different wheels.
Here is a pic of the rough calc, as you can see the calc is working well with the stock data input into the calc, Ive also gone to using a digital caliper to measure wheel n tire overall diameter for the calculations as the info commonly used is off. For example the HPI 26mm rims are credited with having a 72mm OD, but when measurred up they only get 65mm OD, quite a difference especially in end results.
If there is enough interest I will refine the calc and post it up, or if anybody who is skilled in Excel would like to volenteer to make it look more presentable etc I will release it to the public as a Free Doc.
Rac3rX is offline
Old 08-23-2013, 07:29 PM
Trader Rating: 18 (100%+)
Post it up. I'll compare the calc with a GPS reading on my Kemora and maybe you could add a real world estimation based on my results among others...
iTz Nicholas72 is online now
Old 09-04-2013, 04:39 PM
frontedge's Avatar
Trader Rating: 60 (100%+)
Maybe the 72mm is taking tire ballooning into consideration.
frontedge is offline
Old 09-07-2013, 04:47 PM
Might be, but when I factor ballooning into my equasion, I look at the gap between the tire and the road, not the tire and the air, where ballooning is much less then appears. I would think that much ballooning and to have that large an increase is just not happening or exagerated. Still you may be correct and they factor in the ballooning perameters in the spec.
Here is the calc
http://www.2shared.com/file/vsIqVmbl...eed_Calc.html?
Rac3rX is offline
Old 10-10-2013, 02:16 PM
Crazy how such a simple tool can take ALL the guess work out of gearing the Mini 8ight
Rac3rX is offline
Old 10-23-2013, 07:05 AM
Dr_T's Avatar
Nice tool! You're right, who needs guessing when there's math
I've put the math in Excell too to make a spreadsheet of the battery/motor/gearing/wheel options I wanted to try out and it greatly helped me comparing set-ups and figuring out the what makes most sense, see table attached below. It doesn't look that user friendly (don't let a bunch of numbers scare you though), but the left-hand side is user input and the right hand side is what follows from the math.
If anyone's interested, let me know and I'll share it.
Dr_T is offline
