Possibly the best $5.20 I've ever spent...
Wow is all I have to say. 300mAh, 45~90C. And for only $5.20.
I'm pretty impressed. I've tried quite a few different batteries and these ones are by far the best and are so cheap. Plus they fit in the Rally/Truggy/SCT better than any other I've tried.
If you have a Losi 1/24 scale car you have to try these little batteries.
Be careful of them though. I ran a couple of packs on my nitro rc and it went up in flames without warning. No puffing nothing. And they were well looked after.
Destroyed my receiver, servo and KO switch. About $200 worth of equipment gone due to a $6 malfunction.
I gave my other pack away after the experience.
They make awesome 1/10 batteries as well!!
Lipo should only burst into flames if you short them or during charging if you use an unsuitable charger / program. While running easiest way to make a short is by damaging the thin balance cable, which, being unused, just hangs there and may get rubbed against wheels on cars which have no closed battery compartment.
