help with mamba 25 and 6800 motor
Trader Rating: 7 (89%+)
Last time that I use it was probably 2 years ago.
Then a month ago, I wanted to play with my m18pro and everything was ok on the track but maybe 3-4 min later, the car stopped.
It was able to run but only for 1 inch and stop and run and stop.
Anyway, got back home and try different software version with the mamba link. I tried the latest one 1.39 and the motor did not responded at all.
The version 1.16 was ok but was doing the same thing = run, stop, run stop....etc
even the beeping from the mamba ESC was strange.
any advise?
PS: I have ordered an other ESC (no name brand from ebay at 10$). Still waiting.
any advise?
Suspended
..ur esc's bec died like mine did..put a Ubec and remove center wire on esc rx plug and your good..
Suspended
sent a pm..
thanks for the information.
i guess that my mamba is ''kapu''
hey Max, what about the battery? Did you try another? If you are using a 2 year old battery it could be the cause. I used to have that problem...BTW, I also have two M18 all ready to go for next time. I also have 4 M18T and an RC18B(exotek) and the RC18T(exotek)! But we'll stick to onroad...
