Vaterra Kemora And Kalahari Offical Thread
#1681
my 8000kv shows delivered. If I have enough time ill install with pics and do some speed runs tonight
#1682
Hi, does anybody knows a solution to this problem?
https:www dropbox com /s/ i56gg6bh4w2yl3g/IMG_3310. JPG
Sorry, I canīt post pictures yet.
The motor is sealed, no screws to open it and maybe "glue" the parts
Hope you can help.
Hope you can help.
#1683
well I got the cc cm-20 8000kv yesterday. it is not the same size motor as what comes in the kemorra. it isthe same length, same mouting hole pattern, but the diameter is maybe 75% of the dynamite motors.
i feel like im going to burn it up putting it in the kemorra since it wont have near the tq the larger diameter can has
#1684
I have emailed castle. Their 4 pole 20mm diameter motors are designed for cars this weight but unsure how this 2 pole will work. if they give the ok, im throwing it in. may gear it down a little but I want to see 60+ mph haha
#1685
what you might want to do is step up to a 380 size motorhttp://www.trinityrc.net/shop/index....ry&path=72_108
you can do 60+ with the right gearing no problem. Or gear it down and smoke every one at the track.
i love mine.
i love mine.
#1688
Spur gear change
Hi, I just changed my first spur gear and now the car is quite slow. On full throttle it starts slow and then got more speed. I think itīs due to how I setup the spur. Do I have to loose or tight it more?. I followed Raymonīs video but when he said too tight or too loose how do I know how much to tight or loose it.
Hope you can help.
Hope you can help.
#1689
Is your slipper clutch too loose I just had to replace the diffs in my mini 8 and replaced all the bearings but when I ran it after fixing it it would drive slower and take along time to get up to speed so I tightend it till it was still slipping a little but not too much I had it to tight before (there was no slipping when accelerating from a stop) and I cased a jump and snapped two teeth off my ring gear in the front and much more broke off the rear the rear now I run it looser
#1690
#1692
Hi folks
I am back on here & back to rc again after a long 8 year break. so I have got myself a Kalahari still to be used. As I got it last week but work as got in the way ! the joys for working for oneself lol.
however i have also brought some others items \ parts too, what I might have gone a bit over board on but at least I have them now =
Overlander Nimh Battery Pack 1600mah 7.2v Premium Sport W/EC3 - so I can get used to the car standard speeds etc.
Overlander RC6-VSP 80watt 7A Output AC/DC Charger with Fan
2 x Dynamite 7.4V 2000mah 2S 30C LiPo - EC3
3 x Overlander Lipo Safe Sack's
Simply RC LiPo Monitor (Up To 3S)
4 x shocks made of alloy
60wt shock oil
15T Hardened Aluminium Pinion Gear RRP1615 - for when the standard one goes running Nimh
Associated 21155 Pinion Gear 14T - for when running & using lipo battery’s full time & when I get used to this rc truck.
Robinson Racing Mini .5 Mod Blackened Hard Steel Spur 58t
spur \ gear cover = eBay item number: 141289787711
4x Powers PJ35 Glued on White Dish Wheels w/Inserts
4 x Fastrax 10-Spoke Drift Wheels & Tyres
4 x Dynamite 10 Spoke Royal Blue Wheels & Tyres
Turnigy 1700mAh 2S 20C Lipo Pack - might be for my step sons ECX Ruckus Truck
converter cable for the above to make it a ec3
Losi Lipo Protection Pouch
brunox turbo oil spray
Bisley Gun Grease 50ml Tub ( hope this is ok ! )
well I hope this lot sounds ok & hope it keeps me going a while now as my back balance is low for some reason .
also is there a guide for using the oil & grease ?, or do I so I just spray the oil on the moving ball joints & gears etc along with any bearings. & grease in the diff boxes.
I have re set the spur gear just in case it was not right from the factory, however how do I do the Slipper Clutch ?
do I use this way = ( I can not link anything yet )
YouTube =HorizonRC.com How To - Set your Slipper Clutch
also what else do I need to do or keep an eye on ? because I will be using this rc this coming weekend.......
many thanks.
60wt shock oil
many thanks.
#1693
Tired of eating spurs and having no luck at sealing the area (gear cover plus plenty of masking tape plus hot glue, no go, no matter how hard I tried to cover all the spots), decided to try steel
Needed: steel spur (it's 48p not mod 0.5), steel 48p pinion (standard 3.17mm hole) and 3.17mm (1/8") to 2mm adapter (this is made from alu)
Two issues, for those who want to try
The adapter is actually 3.3mm on the outside, so it does not just fit in the pinion. Filing required. I sled it over a 2mm drill bit, fixed at one and in the electric drill and filed the exposed half of it. Swap around, repeat.
The bearing that goes into the spur, needed hammering. Steel spur does not just give up as plastic. Will be funny to remove that bearing. Better order some in advance.
Real world test soon. Being steel on steel it's really noisy compared to stock. Bonus my motor shaft is slightly bent. First stone may just result in a serious bent shaft, since now that is the weakest point.
#1694
have I ordered the wrong things then ? =
? Associated 21155 Pinion Gear 14T ?
? Robinson Racing Mini .5 Mod Blackened Hard Steel Spur 58t ?
#1695
will this body shell fit my Kalahari eBay item number: 191207759610
Kalahari =
Length:13.18 in (335mm)
Width:7.08 in (180mm)
Height:4.57 in (116mm) ( the Kalahari inc the body shell )
centre to centre of arch cut outs 210mm I THINK.....
body shell on ebay =
Length......................................... 315mm
width........................................... 165mm
Height......................................... 100mm
centre to centre of arch cut outs 200mm
arch cut out......................... height 40mm
Kalahari =
