Caveman's mini 8ight project >
Old 04-05-2013, 03:17 AM
  #751
pharro888's Avatar
1.5mm is the most common size on the car. Others are 2mm and 2.5mm.
Most of the nuts are 5.5mm.
pharro888 is offline
Old 04-05-2013, 04:03 AM
  #752
mashimarowu's Avatar
Yea ok, so I'm using a 1.5mm hex and I'm still stripping... Might go buy a high quality single wrench for this car xD
PS I ended up finding out that it was the set screw that came loose. Good thing I don't need to replace the whole diff :P Losi loctites areas where it doesn't need it and vice versa... shameful...
mashimarowu is offline
Old 04-05-2013, 07:33 AM
  #753
bigbadbasher's Avatar
Mashim, it's not the size of the wrench or quality of the tool like i thought it may have been, the size of the screws is NOT 1.5, it's slightly bigger, there is just enough slop in the heads to make them strip easy. The little hex wrench that comes with it is nice and snug but it's a pain to use..
bigbadbasher is offline
Old 04-05-2013, 08:54 AM
  #754
Ahh ok thanks! I wonder if there is a better replacement set of screws to use instead.
Old 04-05-2013, 09:32 AM
  #755
I was going to look into that to..
Old 04-05-2013, 01:15 PM
  #756
Just wondering, but has anyone messed with the diffs before and heard of lrp shark ball diffs?
Old 04-05-2013, 01:44 PM
  #757
Originally Posted by mashimarowu
Oh btw, I asked before, but I wanna ask one more time... What is the hex driver to be used on this car? My hex is loose.
Sorry....I came in late on this....I see.
***Edit......Ok....good.....sounds like you're getting some info at least! Best of luck!
Nitro Ace is offline
Old 04-05-2013, 01:45 PM
  #758
Problem has been solved previously. Its just the screw tops problem, there is no hex that will give a direct fitment without possibility of stripping.
Old 04-05-2013, 01:56 PM
  #759
jwm2's Avatar
Rcscrewz makes a set for the mini 8. I have a set for my 8ight and 8ight-t and they always seem to work well. They aren't nearly as soft as the manufacturers screws so they won't strip out as easily.
jwm2 is offline
Old 04-05-2013, 02:51 PM
  #760
Could someone please measure the distance between the M8 battery strap loops? In other words......I need to know the maximum usable battery length in millimeters. I plan to use a dremel to grind off the little plastic corners that hold the stock size battery....so I can fit a larger lipo. Will this work? My mini-eight is being shipped at the moment.....and I could order some lipos before it comes.
Old 04-05-2013, 03:04 PM
  #761
jwm2, how does your driver fit in the screw head? Is it loose like the stock mini 8ight screw heads?
Nitro, 102 x 31 x 19 mm
To get like a higher height without messing too much, you just put spacers below the battery mounts. You can prob boost the height to like 21mm.
Old 04-05-2013, 03:22 PM
  #762
jwm2's Avatar
My drivers fit perfectly. They are eds brand tools. I learned a lesson with cheap losi tools. Too many twisted heads and stripped out screws and I finally said screw it and bought a high quality set. Since then I don't strip out the heads (besides the steering screws on the m8, but that's due to loctite) and they fit perfectly, no slop what so ever.
jwm2 is offline
Old 04-05-2013, 05:29 PM
  #763
Hah I don't think I can fork out that much being a teenager xD
I notice my esc is getting some pretty high temps at like 130... is that normal? I was thinking of getting a mini fan and mounting it to the body as exhaust. I have seen them around but idk where to get them. suggestions?
Old 04-05-2013, 06:22 PM
  #764
Cheap Losi Tools? Mine are GREAT!!!
Old 04-05-2013, 06:29 PM
  #765
jwm2's Avatar
It's not news just ask around. The losi tools have very cheap bits. Trust me. The eds tools are much higher quality but also cost 5x the price. You really do get what you pay for. It's like comparing craftsman to snap on. The difference is night and day.
jwm2 is offline
