Micro questions for noob
#17
Yeah thats it , expensive but you dont have to watch runtimes with it ..... You will need the Losi wall charger to charge it as well .
Since you have the Micro Truggy and not the Micro T you can fit larger batteries in yours than that 180mAh battery ....
#20
If you make a charging adapter your Hyperion will work fine for charging the Losi LiPos .(I have a DUO II) .....
#21
I'm switched the connectors on my Micro to mini deans so I can use the lipos I already have
