NEW MINI 8IGHT BUGGY FROM LOSI !
#7501
#7502
Hey guys check out my Truggy Project see it here....
http://www.rctech.net/forum/micro-mi...gy-thread.html
#7503
For those who asked about the losi c/f shock towers, they too are 3mm thick like the aftermarket ones.
And for the person that said the servo saver that comes with the m8 will fit on the hitec 225mg, I don't know how you figure that out as the stock losi servo has 24teeth while the hitec has 25teeth.
#7504
Cool man yeah have only heard good things bout kimbough saver...what's that "ammo 3900" motor you are running like? Have'nt heard of them myself...I live in Australia and race my mini 8 with 10th scale 2wd buggies as there are no classes for the mini's...Yet I'm still running stock motor and esc, but have just ordered a Tekin mini rage esc my other mods include RPM a-arms, every aluminium hop up available, RSector cf towers and "quick spur change" chassis brace, Hitec 225mg, HR progressive springs,phat body a wing, Spektrum Dx2s. Also have done my own custom battery strap and am constantly checking for new products and checking this thread is a good way to stay in the loop .............
#7505
Re: shock towers -- I've broken the Losi CF ones, but the Hot Racing towers are holding up great, feel stronger, and have far more mounting points for fine adjustment.
#7507
use the hitec 225mg with the red kimbrough servo saver, you have to trim the top a bit but it works flawless
#7508
#7509
#7510
Is there any sensored solution for the M8?
Is the hitec 225MG the best servo for this car? What's the maximum size of the servo that fits in there?
#7511
You need a "mini" sized servo. The Hitec does the job for around $25. One of the most used mini servos (particularly in 12th scale) is the Futaba S9650, but it will set you back around $60.
#7512
#7513
as some of you know i spent like a grand on hop ups for my m8 and STILL havent got it running yet due to buying the wrong rx, i just made a trade with someone on here for the correct rx, so i'll get a video of it when i get it up and running, i have a hobbywing 35a esc and lots of wires. whats the best way to clean it up and mount this giant ass esc? double sided tape and zip ties or what?
#7514
#7515
awesome, thanks man i'll pick up some washers and do that. i cut my body but with all the wires i dont want any rubbing on the spur gear or anything like that. theres a bunch of wires. i was trying to find a way to tuck them or something. i dont feel comfortable cutting and re soldering
